Is there an alternative cable SAMSUNG BN39-02301A One Connect cable
(Topic created on: 01-12-2019 07:31 PM)
Chris661
I have a Samsung Frams model number UE55LS0034AUXXU it believe it requires a new cable for the one connect. Is there an alternative I can purchase ? I don’t need a transparent cable as the TV is not on the wall.
18 REPLIES 18
Helen94
Hi
did you get any solution to this? This morning our tv wasn't working and discovered the cat had brought in a mouse and it has chewed the cable. Like you it's not on show so don't need the fancy invisible version.
thanks
Helen
Chris661
Nope ! There's isn't unfortunately- check online thou - I got one a lot cheaper and it was a genuine part - just can't find the suppliers name
Helen94
Thanks for speedy reply. When you say cheaper how much? Found one on eBay China for £100 not too sure on authenticity of that. Otherwise I found  £140 - seems bonkers for a cable.. waiting in queue for Samsung rep
Helen94
Thanks for speedy reply. When you say cheaper how much? Found one on eBay China for £100 not too sure on authenticity of that. Otherwise I found  £140 - seems bonkers for a cable.. waiting in queue for Samsung rep. Bloody mouse still at large!
Chris661
I think they quoted me £180 at the time - I think I paid £120 from the Uk
Helen94
Thanks for your advice - good to know rough price so I know what I'll have to pay is sadly about right -  it does seem extortionate for a cable. Cheers
Chris661
Found it - smartappliancesuk but there’s none in stock - try this but not sure 🤔
ttps://www.ebay.co.uk/c/12007092554
Helen94
That's the Chinese one on eBay - just worried the order might disappear into a Corona black hole! Going with an eye watering £165 on spares2repair.co.uk The TV not working right now is a biggie. Take care thanks for help
Chris661
It’s not good business at all with Samsung - very disappointed
