Help ! weak no signal pick up in australia sydney
(Topic created on: 24-05-2022 02:12 AM)
Gaga1688
hi, I moved my Hong Kong Samsung TV to sdyney, well connect to the wall antenna, TV searching the channel but kept showing -  "no signal" . does samsung TV has region issue ? Hong Kong samsung TV cannot used in Sydney. Sydney used digtal boardcasting.  anyone has this kind of problem ? pls give me some advice
3 REPLIES 3
BandOfBrothers
Samsung Members Star ★★
You don't mention the Televisions Model etc @Gaga1688
Check that your TV has the required bands and frequencies that can be used in Hong Kong.
If necessary contact Samsung Support by phone or email and they should be able to advise.
I've asked for your post to be moved to the TV section as you've posted in the Samsung Galaxy s²¹ Boards.
Hopefully you then may receive more detailed responses.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Pugs1957
SuperStar
Your TV won't work in HK, they use a different system to Aus, so you will need a set top box to receive HK channels.
JAMES4578
Yes Hong kong uses  DTMB whist in Australia it is DVB-T , some information here   http://en.dtvstatus.net/
