Help! Connection icon displayed
(Topic created on: 23-08-2021 09:19 PM)
SKEane
I returned home after a week away to discover the power cable had been disconnected from the tv. When I reconnected it and turned it on, I was greeted with a screen that should the tv and the dock with a hdmi cable between them with two blue arrows. When I disconnect the hdmi, the screen goes black until it’s plugged back in. The remotes are also not working despite the red dot below the tv blinking indicating that it is receiving a signal.
1 REPLY 1
So, you went away and left the TV plugged in but returned to find it unplugged and the cables messed around with... I'm guessing that someone has been 'gaming' on your TV while you were sinking Piña coladas in paradise... Check the cables are all in the right holes then select the correct audio visual input that you use. I would also check cables for internal breaks by substituting a new one.
