HDMI as sound option disappears sometimes... why?
(Topic created on: 27-04-2021 09:28 AM)
richardcbristol
I have a UE55TU7100KXXU 55" Smart 4K Ultra HD HDR LED TV and very pleased with it. When I originally set it up with my old DVD 5.1 home theatre system was pleased to see that the sound output worked from TV to surround sound via optical output, but also via HDMI. Not only that but I could change the volume when HDMI was set as sound output, and the surround sound would turn on and off with the TV. Perfect! This is not an eARC unit as far as I am aware.
However when the kids get to the TV somehow they are pressing some option (and I've no idea what they're doing, tried to reproduce it but not succeeded), the HDMI option disappears from Sound selection. TV Speaker appears to be selected, but the sound is still coming out of the surround system (via optical presumably). Only now i of course can't change the volume from the TV remote, nor will the surround sound turn off with the TV.
To fix this I've not found a 100% reliable method. Sometimes changing TV output to the home theatre system will cure it (i.e. i can see and select HDMI as the output. Sometimes it doesn't. Sometimes it seems to fix itself (I've pressed volume up not realising the home theatre system was still off, but that actually triggered the home theatre to power on). Sometimes I have to hard power it off and on again and even then it doesn't always work.
Clearly there's something a not working perfectly in detecting that the HDMI I have plugged in is a viable sound output but I just can't work out what i might be. Any suggestions?
Virtually all our TV is watched from the smart TV menu (very impressed, works with all the apps we need to use), so really I just want it so it reliably outputs sound to the surround sound unit and turns on and off with the TV and lets me control volume. And that no pesky kids access youtube or netflix by pressing buttons I'm not pressing as for me it always stays on HDMI as the sound out but somehow when I come back to it after a some time with the kids having used it it's no longer a selectable sound options! 🙂
8 REPLIES 8
Antonio Zhu
Hey, this might be a bit late but for anybody having the same problem, our Samsung Series 6 43" TV had the same issue with the HT-C5500 and I fixed it by unplugging and plugging in all HDMI cables.
richardcbristol
Seems mad that this workaround works and triggers the tv into life. I also found going on holiday and leaving it off at the wall for a week fixed it. But that's not always practical :smiling-face:
Members_Fu7Fyjw
Any chance you found a solution to this.
I've had my TV for over 6 months and it's only started doing this.
richardcbristol
Afraid not. Other than the turning it off for ages and turning it all back on again. I ended up swapping my old surround sound for a bose soundbar
MamaSpat
Richard - are you by chance using a cable box as well?  I keep having issues with my Bose soundbar not being recognized via HDMI and can only connect via Bluetooth.
richardcbristol
Thankfully no major problems with the bose soundbar and hdmi. Although sometimes it turns itself back on again after being turned off...
abperiasamy
This is going to be my last Samsung TV. I bought a new Denon receiver, thinking it was my Yamaha receiver. It looks like buggy firmware in Samsung TV. Others have reported this issue for ages. Samsung doesn't seem to care.
richardcbristol
Tend to agree. The remote control / UI is pitifully slow on my TV. Utterly ridiculous. Tizen I expect to blame. Combined with the audio out issue via HDMI wouldn't want to risk same in future.
