21-09-2022 10:05 PM
I am trying to connect my Freestyle projector to my PC to use it as an extended screen. I followed instructions on a projected screen and online instructions about connecting Samsung Smart TV.
The PC is connected to the router by cable, and Freestyle is connected to the wireless network. I can see the projector as a device to connect, but the connection only lasts less than a second and gets disconnected. It is the same in case both Freeway and PC are connected wirelessly to the network.
The only way I could connect PC and The Freestyle was by using the Easy Connect app. The video lagged a lot, and I hope using a direct connection can improve the experience.
05-01-2024 08:37 PM
having the same problem but can not get easy connect to work also.
miracast give me an error code of 45 which says this hardware device is not connected to the computer
also get a Local Area Connection *26 what ever that means!
am about ready to send it back!
24-01-2024 08:36 PM
still having the same problem
guess Samsung does not care
20-06-2024 08:42 PM
the same for me, did all require instalations and config however my profile did not appear in the freestyle workspace automatically.
