Go to solution Solved
Firmware for UE65TU7100KXXU CORRUPT
(Topic created on: 19-06-2021 06:40 PM)
robt66
As the title says the new firmware download for the above tv is corrupt and i have tried multiple usb drives and during the extraction the following appears every single time and i have also downloaded the file more than once still the same everytime.20210617_161917[1].jpg
robt66
Just tried again today and the update finally extracted without any errors,so Samsung must of rectified the file error.
3 REPLIES 3
KholaI
Hey @robt66
Are you following the steps mentioned on this website:
https://www.samsung.com/uk/support/tv-audio-video/how-to-update-a-samsung-tv-via-usb/
robt66
Hi Kholal i have done the update before more than once on other Samsung tv,s as well and never had an issue the file itself is corrupt and i know how to use a pc having built them from the ground up and i have also tried downloading the 2 files for the firmware both are corrupt.
robt66
