Faulty Samsung TV
(Topic created on: 09-10-2017 07:26 AM)
Jodo
I have had 2 new 43" Samsung tv's each of which stopped working almost straight away. aaaaaai find that the fuse keeps blowing. Inside 1 month from new Curries will give me another one but I don't want to keep carrying another home, setting it up, only to find the same problem. Either these have an inherent fault or I suspect the power lead connection is not tight enough and sparks, causing the fuse to blow. It is again working for now but I will tackle Curries again as soon as I get time.
Any ideas?
1 REPLY 1
Techbox
I am having this exact same problem on the Samsung SE9B505102. motherboard. Did you ever find the solution?
