Connect a Wii to a samsung tv
(Topic created on: 16-05-2023 11:57 AM)
wisel
Hello folks,
I have a Samsung UE40 TV which is now spare. I want to use it to connect a Wii to. I see the Ext1 (RGB) socket on the TV but cannot find the right cable to adapt that socket to the RGB leads from the Wii. Here is a picture of what I think is the right socket. Advice please on the description of the socket type, or a part number to order. Thanks in advance. Robtv temp.jpg
1 REPLY 1
Neo001
Legend
I had bought this on Amazon. Output from the adapter is HDMI. It requires a separate power source.
Just Google it and you will find many options.
https://www.amazon.co.uk/RXDF-Converter-Ondersteunende-Samengestelde-DVD-spelers/dp/B08MQDFBSD/ref=a...
