Go to solution Solved
Common Interface
(Topic created on: 02-07-2020 11:11 AM)
Pat551
Just purchased Samsung TV UE43 TU8500U. Do I need to fit the Common Interface card that came with it. No mention of it in the manual.
JAMES4578
Hi @Pat551   No you do not need to attach the Common Interface  and  TV will work perfectly well without it. sometimes called CAM (Conditional Access Module)   It is a means for accessing some subscription services (you need to insert card in the slot) in the past it could be used  for Setanta /ESPN   but  no longer the case since BT Sports acquired ESPN.  Nowadays tends to be an option  for services on international satellites.
satellitetveurope.co.uk/cam
33 REPLIES 33
ashyt16
Navigator
No.
JAMES4578
don123
I've got Samsung model LE32D400E1W cant get an common interface card can anyone assist please
JAMES4578
HI @don123   Are you looking for international sevices?   If so  could have a look at these links for instance and ensure it is compatible.  https://www.smartvisions.co.uk/product/original-common-interface-card-adaptor-slot-5v-samsung-tv      https://www.amazon.co.uk/s?k=common+interface+card+for+tv&i=electronics
sansung2
You can buy them online  about £8
Members_41n0ph5
I just bought a new TV and don't need mine. You want it?
Fekkitt
i have two of them if you want them for free
Mozee
Hello Fekkitt,
I need a common interface adaptor if you still have one. Many thanks
Forestgirl
Do you still have the common interface adaptor? If so can I please have it.
