BBC Red Button not working
(Topic created on: 18-04-2017 07:12 PM)
MarkGovier
UE48H6700 with current software; I just checked AND did a factory reset. The BBC Red Button+ service (nor the plain Red Button) won't work. It does on a connected BT TV box AND the internet is connecting as the iPlayer, YouTube etc. does work. What can I try?
40 REPLIES 40
KellyM
Helping Hand
Hey @MarkGovier,
Are you still having problems with the BBC Red Button+ service? Are you receiving any error messages?
MarkGovier
Hi. Yes, still coming up with the error stating that the app or firmware needs to be updated. I've tried everything I can find in the menu structure to cause an update to the app but nothing seems to make any difference. I even did a restore factory settings a few days ago. Internet connection is working fine as YouTube etc. work perfectly. It's just the new RedButton+ features (as far as I know).
Error messageError messageChecking for updatesChecking for updatesCurrent firmware versionCurrent firmware versionApp update settingsApp update settings
KellyM
Helping Hand
Thanks for providing more details!
Can you try Smart Hub > Apps Settings > Channel-Bound Apps > On then turn the TV off and on again.
Let us know if this allows you to use the Red Button+ service.
MarkGovier
Hi,
I'm afraid that doesn't work. The function is greyed out and says the function isn't available. This was why I tried a factory reset a couple of weeks back.
What next? Is there an even more thorough reset?
KellyM
Helping Hand
Are you on the TV Source when you try to select this option? Have you tried resetting the Smart Hub? What steps did you take to reset the TV previously?
We'll try and get to the bottom of this for you!
AnthonyShore1
Hi
have you managed to sort this I'm having the same problem??
cheers
MarkGovier
Nope. No further input from Samsung.
Red button+ still not working.
If anyone at Samsung is watching forum this please let us know how to proceed.
MarkGovier
I think I missed this reply. How do I reset "Smart Hub"?
How do we perhaps uninstall and reinstall iPlayer?
AnthonyShore1
It's in settings, takes about 5 mins
