Go to solution Solved
BBC Iplayer will not work on UE32D5520
(Topic created on: 21-06-2022 11:43 AM)
Snowman1
When I try to start BBC Iplayer on my UE32D5520 I get "connecting" then a blank screen with a single line display "previous page". The same happens with BBC News. I tried software updates but there are none so I presume I have the latest version.
Can anyone help please
antikythera
Black Belt
It's an 11 year old TV even if you bought yours more recently so more than likely iPlayer needs newer processing hardware now which no firmware update (if Samsung could be bothered with a set that old) would fix. You'd need a streaming device to send iPlayer from your phone or tablet to the TV instead. I use a Chromecast with mine but iPlayer is on Fire Stick too. EDIT - I did some digging, the last firmware update for the TV was in 2015. In 2019 there was a major upgrade to iPlayer that needed another upgrade on Samsung products. So it's entirely feasible the same has happened again 3 years down the line.
3 REPLIES 3
antikythera
Black Belt
Snowman1
Thanks for the info. I had wondered if it was something like that. As my Smart TV is now "Dumb" I presume there is now no benefit in having the Lan connected.
antikythera
Black Belt
If none of the apps function then not really, you may as well disconnect it
