Audio Sync
(Topic created on: 29-07-2018 11:26 PM)
DM417
I have an older (5 years) 60" Samsung plasma tv. The digital audio does not match the lips of the people on the tv. I keep resetting this but it doesn't hold once the tv is turned off and back on. Sometimes I set the audio at 50 and it works for awhile then it doesn't work and I set it at 0 and then it works. This needs to be changed every day and sometimes more often. I do have a soundbar connected but this problem is also present without the soundbar and using the TV's speakers
1 REPLY 1
AntS
Hi @DM417. :smiling-face: What's the model number of your TV and software version you've got on it?
(I'm also guessing that by "audio" you mean the Audio Delay.)
