Go to solution Solved
Amazon prime error code 9345 Help!
(Topic created on: 08-09-2024 09:35 AM)
Nigel Tullett
For some reason we can’t get Amazon prime video as of yesterday, get error code 9345, have tried all reboots of BB router, refresh app, checked for updates, account is fine,  works on iPad. So it’s something related to Samsung TV which is 65” curved is causing issue. Any ideas?
Nigel Tullett
Thanks, I checked that and it does seem to flash up as being possible issue but mine was fine . The issue was fixed by setting the Smart Hub, this forced a re log  in of all the apps and fixed the Issue.
4 REPLIES 4
manecink01
Im not sure what to do now
Babishko
Big Cheese
Babishko
Big Cheese
This is very often a payment card issue, so best make sure your card is up to date before hitting the link I have given you. Good luck with this very troublesome problem. Below is a concise listing of solutions hopefully more related to your television:
Nigel Tullett
