AirPlay goes into Multi View mode rather than full screen.
(Topic created on: 14-10-2023 09:26 AM)
rafm5
The full screen option worked fine for many months. Now I have to click 'resize screen' every time I do AirPlay.
Samsung S95B TV
Firmware 1520.7
7 REPLIES 7
-Robot-
Samsung Members Star ★
Probably an airplay problem 🍏 😂
rafm5
Let me rephrase the question: why does TV go into Multi View mode after selecting AirPlay?
When I press go back on the remote, it goes back to full screen mode.
So I cannot see how AirPlay affects Multi View mode. It is the TV that turns on Multi View IMHO.
Tested on iOS15, iOS16 and iOS 17
MorningBlunt
Troubleshooter
Sure there's an option in Smart Things on the phone that allows this to be changed. Check the settings.
MB
rafm5
Apple AirPlay is technically a feature with no settings, at least from an end-user and Apple device perspective.
I've tested it on 3 different iOS versions (all of which were fine before) and 4 different devices.
S95B has two Multi View settings, but they don't work.
Najsicek
I resolved it by turning this ***** off
TheAnders
Thank you, thank you, thank you!!!!
This fixed it!
I don't think I ever would have figured it out!
SoloScuba
Perfect, just got my QN65S95DAFXZA yesterday and was playing around and having it default to multi view with AirPlay, a bit annoying.
