65" QN95B Neo QLED advice??
(Topic created on: 18-06-2023 09:01 PM)
Members_dBw7nKG
Hi all,
I have recently took delivery of QN95B Neo QLED 4K HDR TV  and I am looking for advice. I am not happy with the way the TV has arrived. It has been fully built and is currently installed in my media cabinet however, the back panel plastic in the bottom right corner is out of alignment to the TV. The plastic is lifting outside of the frame and is not the usual build quality I have had in the past. The rear plastic is also extremly thin, unlike any previous generation I have had from Samsung previously. I guess my question is: Is this normal? and if not will it cause issues if left?
Samsung chat have not given me any answers and I am not happy after the money I have spent on this.
3 REPLIES 3
-Robot-
Samsung Members Star ★
Where did you get it from?
Members_dBw7nKG
Direct from Samsung UK
Ginga_p
Hotshot
The plastic panel on the back is thin but sits flush against the frame of the tv. Will cause problems with speaker vibration at some point.
G G
