Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
USB bluetooth for audio Samsung UE40F5300
(Onderwerp aangemaakt op: 28-10-2018 07:47 PM)
3014 Weergaven
ESKM0
Opties
My tv model is not bluetooth ready however it has an audio outlet where I can place a bluetooth adapter to connect to my wireless headphone. Problem is that 99% of bluetooth adapters have a USB input instead of a traditional headphone input.
Can I use USB bluetooth adapters in the tv USB outlet instead of having to use the audio outlet to connect audio my wireless headphone? Is audio also transferred via the USB outet of the tv?
Thanks in advance,
ESKM0
2 Antwoorden
DickKoster
Opties
Hi @ESKM0,
What is the full Model Code of the TV? UE40F5300AWXXN perhaps? Tv from 2014.
It's written on the sticker on the back of the TV and must be ending on XXN.
What is the current software of the TV? Must be Version 2126.0.
Are you living in the Netherlands?
And no, there is no audio output through an USB connector on the TV.
These are only meant for power supply for an USB device or showing foto’s or video’s etc.
I will talk to you later further on.
Why not try this one: https://www.marmitek.com/en/audio/receivers/boomboom-75-bluetooth-audio-receiver-with-battery-pack/
Groet, Dick
I don't know everything. Just trying to help.
JoeriS
Mastermind
Opties
Good evening @ESKM0, there's a lot to be done with USB ports on a TV, but sending audio is unfortunately not one of the options. However, if you Google for "Bluetooth jack transmitter" you'll find the adapter you're looking for. But since we don't make them ourselves and I don't have any personal experience with them, I can't advise you in which one's the best.
members-moderator-signature-launch-february22-800x200
