Sluiten
annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Oorspronkelijke onderwerp:
oled S90c cadence pacing problems after firmware 1410.1 and 1420.9
(Onderwerp aangemaakt op: 04-06-2024 10:34 AM)
1356 Weergaven
GravityRZ
Opties
Hello,
my tv was perfectly working on 1310 firmware.
samsung recently introduced 1410.1 which would solve audio problems and new menu features
i installed it but now i sometimes have a screen which seems to stutter
after investigation this problem seems to be called frame cadence/pacing
it is not there all the time but sometimes it looks like it is repeating/forgetting frames
Is samsung aware of this problem eg will there be a solution soon.?
firmware 1420.9 is online but that did not solve it either
11 Antwoorden
GravityRZ
Opties
can you post a link. i searched the website but can not find anything as simple as error report
GravityRZ
Opties
ok, clear. iphone users however are left in the dark(no app exists)
Ajay-A
Opties
Hallo @GravityRZ,
Thank you for yourt message. Is this with the apps on the television or through a tv box or casting?
With kind regards,
Ajay
GravityRZ
Opties
i do not use apps on the tv. it is through both regular cable broadcasts as well as HDMI port(AppleTV 4K)
the problem was not there with 1310 but now with 1410 and 1420 it is there.
thee is not way for me to report it because the samsung members app does not work on my iphone
surely samsung must recognize how important it is to send in feedback
Ajay-A
Opties
Thank you for your response. is this also after resetting everything and can you give me your full modelcode?
With kind regards,
Ajay
GravityRZ
Opties
yes, after full reset problem still there, more vissible on the appletv4k than on regular broadcast.
it is not like it is happening every minute but when it does it looks like it is dropping frames
e.g when you have fast movement is looks like it skips frames and you see what looks like interlacing
full code:QE55S90CATXXN
Ajay-A
Opties
Thank you for the information GravityRZ,
I will contact our Product Specialist about your situation. As soon as possible I will get back to you.
With kind regards,
Ajay
Ajay-A
Opties
Hallo @GravityRZ,
To determine the exact problem our Product Specialist ask if you can try the apps on the television to check if the issues our also present there. Than we know were to look. Let me know if it is possible.
With kind regards,
Ajay
GravityRZ
Opties
i tested with the internal mediaplayer app and the problem is visible with internal apps as well
firmware 1310 did not have this problem.
all the things changed in 1410 and 1420.9 to solve audio dropout problems caused serious problems with the video output.
