A problem in tab s9+battery
(Topic created on: 12-07-2024 08:17 AM)
s_tabs9
Is this a normal battery draining?
It drained 74% only in 5 hours ?
And it gives me 6 to 7 hours scren on time in total
2 REPLIES 2
Hi. If the tablet is new, it is normal. I saw your battery activity and it seems a normal draining seeing that the tablet is new. He needs about a month to get used to how you use it and last according to your routine. Try to check if you have some app in background, maybe you could improve something.
Stefano
s_tabs9
Two weeks ago I got 9 hours screen on time but since then I get only 6 7 hour max.
