Tap to hide flex mode control panel
(Topic created on: 04-11-2022 07:11 AM)
Tehki8
Voyager
When using a video app e.g. Netflix with the screen in a partly folded position, e.g. to the top half shows the video and the bottom half displays the control panel i.e. volume control, touch pad etc.  It would be super useful to be able to hide the or temporarily turn off the bottom screen control panel so it is less distracting when watching videos.  Whilst keeping the video in the top half only. When you need to use the control panel again, just tapping the bottom screen will make it reappear.
At present there's a X button located in the top right corner of the bottom screen control panel, if selected it will close the bottom control panelz this will exit flex mode and the video to display in the entire screen, which causes the video to expand in to the partly folded crease because the screen is part folded in flex mode. Which defeats the flex mode purpose.
1 REPLY 1
MagdalenaPo
Beta Moderator
Beta Moderator
Hello @Tehki8
Thank you for sharing your suggestion. I will pass your suggestion to the development team who will consider implementing this option. 🙂
Have a nice day!
