in data 15-03-2018 05:20 PM
SALVE! QUALCUNO POTREBBE AIUTARMI????
HO UN TV SAMSUNG LCD LE40D503F7W E DOPO AVER EFFETTUATO L'AGGIORNAMENTO DEL SOFTWARE SCARICATO DAL SITO DELLA SAMSUNG (DI SEGUITO IL LINK) http://www.samsung.com/it/support/model/LE40D503F7WXZT
NON FUNZIONA LA PARTE SUPERIORE DEL TELECOMANDO, OVVERO IL TASTO POWER, SOURCE, IL TASTIERINO NUMERICO E L'UP AND DOWN, INOLTRE NON FUNZIONA NEANCHE IL TOUCH SULLA TV... HO EFFETTUATO PIU' VOLTE IL FACTORY RESET MA NULLA E' CAMBIATO....
HELP ME !!
in data 16-03-2018 06:38 AM
