battery problems
(Topic created on: 22-10-2020 02:38 PM)
arman1401
Anyone else having issues with battery. It's been 2 hours since I've upgraded to One Ui 3.0 and with minimal usage my battery has dropped 82% to 60% with at least 20 minutes of SOT
9 REPLIES 9
Aumeisters
Pathfinder
SelbyL
Pioneer
definitely setting higher battery drainage bit expect this to improve with next beta releases. nowhere near as bad as the original oneui beta a few years ago though
arman1401
I have the s20 and my SOT was around 6 hrs a day with 2 charge cycles 💀
Danlav313
Pioneer
try checking Samsung apps for updates as some won't be optimised for the new software. I updated all apps and restarted my phone and it's been fine since but before that the battery drainage was higher than normal
zainhassan
my s20 ultra is really bad it would die within 2 hours which sucks badly don't know what to do every 2 hours I have to charge 🤦🏽
K3n0b1
Navigator
Battery drain usually improves over the course of a few days when a new OS starts for the first time.
MartynaK
Beta Moderator
Beta Moderator
@arman1401,
If the problem with your battery life persists, please send log files via the Samsung Members application so that our developers can analyze the issue :hand-with-index-and-middle-fingers-crossed:.
masterzoin
Navigator
yes I notice this also I just sent error logs off
Dyceman
Navigator
seems about 4 hours is what I'm getting atm with 1 hour screen on time Screenshot_20201025-085016_Device care_6995.jpg
