Very odd network issue
(Topic created on: 08-10-2021 06:40 PM)
Jamesn123
Pioneer
Took me forever to figure this out, but whenever my S21 ultra is locked it's causes massive ping spikes across my network and on my router. As soon as I wake the device up it works as normal again. This is on WiFi. I've tried disabling WiFi power saving etc. Still have the issue
18 REPLIES 18
Leod
Same issue here, kills wireless access for my other devices until I disconnect my phone. Enabling WiFi safe mode in developer options seems to help a bit and putting phone onto routers guest network. Something definitely not right.
Jamesn123
Pioneer
It's really weird. What does the WiFi safe mode do? Are you running WiFi AX or AC?
Leod
AC, the safe mode option says it priorities stability over performance
Leod
Very irritating bug
Jamesn123
Pioneer
Ah okay I am using AX so shows it's across all protocols
Jamesn123
Pioneer
Yes it makes it impossible to play games as they spike to 1000 ping every 30 seconds or so
Leod
Yup, literally kills wifi access for every device in my house until my phone is disconnected which causes chaos.
Jamesn123
Pioneer
Personally I may have to go back to stock firmware, this particular bug is system breaking for me
Leod
Had the same thoughts, giving it a few more days to see if there is another update but if nothing by next week will have to roll back
