USB Data Transfer Does not Work
(Topic created on: 15-09-2026 09:19 PM)
Members_w2XelMw
USB Data transfer is not working ever since I upgraded to OneUI 9 Beta. (On Beta 2 now)
I cannot connect my phone to my pc to access files.
I cannot use my USB telescopic controller on my phone.
No data is sent.
Restarting, wiping USBSettings cache, USB Debug Mode, File Transfer by Default.. Ive tried everything and it just does not work.
Can this get fixed?
The same cable and controller works for my S23FE running OneUI 8.5
Products mentioned in this post
1 REPLY 1
MartynaK
Beta Moderator
Beta Moderator
@Members_w2XelMw
Thanks for the detailed report and for confirming the cable and controller work correctly with another device. Since you’ve already tried the usual troubleshooting steps, please submit an Error Report through the Samsung Members app so the issue can be investigated.
