UI issue.
(Topic created on: 3 weeks ago)
MatthewW191
Has anyone else noticed the UI bug with the volume? It doesn't show the icon when adjusting the sound.
5 REPLIES 5
icey2566
Is there anywhere i can download the beta for s25 fe PLEASE
danfish13
Pioneer
Make sure your in a supported region with the phone also being from that region ie I assume your from uk as this is uk forum. You go to Samsung members app and scroll down to the one ui beta banner and then join the s25 beta. And then check for updates and you will have it
Lohraak
MatthewW191
I wonder if the colour makes a difference. To fix it I have to drag it to a then back up and it'll reappear.
AgnieszkaMP
Beta Moderator
Beta Moderator
Hello @MatthewW191,
Have you tried changing your colour palette to see if the icon appears? If it doesn't, please report it via the Samsung Members app. Please remember to attach the log files so that our developers can analyse them 😊
Have a great day! 😎
