Mobile network issues.
(Topic created on: 17-09-2022 02:30 PM)
lintern
Is anyone else experiencing mobile network problems? The signal on my device for the most part is not working and on the odd day it decides to work its very slow. All i have with my dual sims is a circle with a dash through it, its getting impossible to use the device out and about.
4 REPLIES 4
Anonymous User
Not applicable
Have you tried resetting network settings ?
I've not experienced the issue myself much, but signal where I work is rubbish anyway so I'm using to getting only a couple of bars and then nothing even on final builds.
woodlouse
Troubleshooter
Very slow here. YouTube is worst affected. I've reported it.
lintern
Was on the beta and now back on the stable release which did fix my issues but now its happening again.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @lintern,
Sad to hear that the problem still appears 😓 Have you tried performing Wipe Cache Partition on the device after the issue started? If not, you can try that and see if that fixes the issue. Please also report the error through Samsung Members app so that the developers can take a look 😊
Have a good day!
