Edge panel
(Topic created on: 26-01-2025 06:31 PM)
Yogi-
I am having trouble accessing the edge panel to launch the compass or surface level tools. Could you please let me know if these are available on the Samsung S24 Ultra?
7 REPLIES 7
ARamsay
Pathfinder
The custom edge panels and the store page for them were removed in OneUI 7 😞
rmj99
Pioneer
The Tools panel which has the compass and such is still available (it's a stock system one not a third party panel so it shouldn't have been removed).
There was a bug in beta 2 which caused it to disappear but that was fixed in beta 3. You'll have to re-enable it again though in Settings->Display->Edge panels to see it
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Yogi-,
Hopefully the solution above helped solve your issue, but if not (and you have the newest Beta version installed) - please send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
viv_matt
Helping Hand
The panel is there for me under settings if I understand your query:
Yogi-
Thanks this is working fine. 👍😊🙏
S25UltraUKuser
Helping Hand
So, if I get my new 25 Ultra soon, and set up from fresh. Will I lose the edge panel feature?
Or, do I have to smart switch over my set up that's using edge panel to keep them?
barnyd
I have enabled the compass in edge panel but I can't open it on my a25 5g
