Edge panel icon size?
(Topic created on: 02-09-2025 06:22 AM)
NptCnty69
Is there a way to make the Edge panel icons smaller so you can fit more into a single column?
1 REPLY 1
MartynaK
Beta Moderator
Beta Moderator
Hi @NptCnty69,
Currently, the option to directly customize icon size in the Edge panel is not available by default. I'll forward your suggestion to our development team 😊.
