Charging issue
(Topic created on: 04-04-2025 12:55 AM)
Michael221097
Is anyone else having charging issue since the last beta update my phone seem to pick when it want to charge and will go off charge and go back on when it want and the type c port will only work in one direction and it not the charger or cable as tried it with my other s24 ultra that not on beta or has my phone developed a fault
3 REPLIES 3
Gavin1979
It sounds like your phone could possibly be faulty.
I have a Samsung Galaxy S24 Ultra, and I haven't had any problems or issues regarding charging my phone since the last Beta software update.
You may also want to look at your phone charging settings as well.
This can also affect phone charging.
BeataPe
Beta Moderator
Beta Moderator
Hello @Michael221097 ,
If you manage to rule out physical damage and the problem persists, I recommend reporting it through the Samsung Members app so that developers can investigate the cause of the situation.
Have a nice day!
Michael221097
I sent a report a while back
