Battery protection
(Topic created on: 18-09-2025 05:25 PM)
AKEEB
Voyager
It is rather frustrating that the battery protection activates upon plugging in the phone, restricting the charge to 80%, and requiring manual adjustment in the settings to revert to the basic charging mode. One might wonder why the preferred setting cannot be retained.
6 REPLIES 6
Michael_S24Ultra
I've not experienced that problem at all just checked on mine by plugging charger in and it doesn't activate the battery protection perhaps others have had this problem but my s24 ultra is behaving as it should
mkk7781
Helping Hand
U can turn it off in settings
MartynaK
Beta Moderator
Beta Moderator
Hi @AKEEB
If the issue persists, please report it via the Samsung Members app and attach log files so that our developers can investigate :hand-with-index-and-middle-fingers-crossed:.
AKEEB
Voyager
I did everytime when I plug the charger in battery protection turns on automatically to 80 limit
AKEEB
Voyager
I have reported 2 times in beta 1
SlimFan
Helping Hand
u can set a routine, i did too, where when ur phone is at 80percent, battery protect is disabled, then at 95percent u can set it to maximum protection 😉
hope this helps 🙏 😜✌️
