Battery issue
(Topic created on: 13-03-2025 08:19 PM)
johny193
Why so beta version take to much battery battery is very reduced
4 REPLIES 4
Glenntech
Samsung Members Star ★★★
If you are on the One UI 7 Beta
Any One UI 7 Beta issues and questions
Please use the Beta Forum
Using the phone you have the Beta software on.
Go into the Members App and the first page you see should be the Beta Forum.
TechZilla
It is a beta software, this means it will have bugs within it so testers like yourself can report back to Samsung so they can fix it in the next update.
TechZilla - Samsung Members Star
Gedjones
Voyager
Again this is in the Beta discussion area. So it's in the right place.
You need to turn in your star.
Obviously, Star members are just earned by posting anything about everything and not knowledge.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @johny193,
Thanks for reporting! Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause
Have a good day!
