No sounds and vibration when call coming.
(Topic created on: 23-04-2025 06:33 PM)
HansKloss79
Just founded issue with ringtone, vibration. Nothing works, doesn't matter what it's set up. No sound or vibration when someone called me.
Thank you
2 REPLIES 2
Clive7409
Voyager
May be worth reporting this via feedback to dev team so they can investigate
BeataPe
Beta Moderator
Beta Moderator
Hello @HansKloss79
Thank you for reporting this issue. Please also send an error report through Samsung Members app so that the developers can take a look at what may be the cause.
In the meantime, here are a few tips that may help:
- Make sure Do Not Disturb mode is disabled
- Double-check the Sound and Vibration settings
- Test if the issue persists in Safe Mode to rule out third-party apps interfering
Have a great day!
