Battery drain overnight
(Topic created on: 23-08-2025 06:27 AM)
Xperixon
Pathfinder
Hi. Anyone else have the same problem? Overnight google play store, google chrome, and google play system draining my battery. 10 percent Overnight. I tried everything, but keep running on the background.
6 REPLIES 6
weskerevil
Helping Hand
I charge to 100% overnight and apart from 7 apps everything else is in deep sleep try that 👍
WhatIsLife
Helping Hand
I don't monitor battery use that heavily but is 10% overnight pretty good? I don't think id be unhappy with 10% in approx 8 hours
Stevo-007
Pathfinder
Hi
Only once had to fault, battery which wasent really battery it charged extremely quick one day.
I see a lot on here, people having problems RE battery.
I only charge my phone when it's low. So basically when it's done.
Feedback submitted FastGharge ages ago.
Steve
Xperixon
Pathfinder
When i using my phone with 10 percent battery life i can watch 1.5 hours video. The phone in standby on the night and using 10 percent. Not good. On one ui 7 it was2- 3 percent overnight.
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Xperixon,
If you experience excessive battery drain - Please send an error report through Samsung Members app so that the developers can take a look at what may be the cause.
Gav4b
Voyager
The battery is general is really bad on the s25 ultra since one UI 8 , I used to get very good battery when I first got my s25 ultra on one ui 7 I used to get 8 - 9 hours of OST but I now only get 3-4 hours with battery saved mode on and everything else turned off just hoping the battery is bigger on the s26 ultra as my s23 u gets more battery then my s25u it's shocking
