Battery drain beta 5th version
(Topic created on: 22-08-2025 08:46 AM)
Fooey
Navigator
Anyone getting battery drain with 5th beta update. Battery drained 12 with screen time 34 mins.
5 REPLIES 5
weskerevil
Helping Hand
Yep reported it and I've had a sarcastic comment from a member on here 🙄
walshyboy
Battery has been great with Beta 5
weskerevil
Helping Hand
Really 🤔
Xperixon
Navigator
Try to clear system cache. For me it was sorted the battery problem
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Fooey,
If you experience excessive battery drain - Please send an error report through Samsung Members app so that the developers can take a look at what may be the cause. You can also try clearing system cache as suggested above
