alarm clock no sound
(Topic created on: 30-05-2025 11:38 AM)
Stephencbr600
any one else have a problem with no sound when the alarm clock goes off ,
6 REPLIES 6
srs0591
Navigator
Not me. Have you checked alarm settings and made sure this isn't checked? 1748601668268.jpg
Stephencbr600
thanks for you reply srs 👍
you pointed me in the right direction , there was an actual update for the clock on the app store all working now 😊
AlexLeeds
Navigator
Hi, I did the clock update as part of setting up after the Beta download. I can confirm my alarm sound does work
Stephencbr600
all working now after the app update , on the plus side I got an extra 3/4 of an hour in bed 😮
Frub8903
Yeah I've found none of my downloaded mp3 alarm samples work. I then further investigated and discovered that even the embedded Samsung tones now just come up with unsupported audio file. I only found this out after installing ui 8 yesterday and then waking up an hour late for work this morning after my alarm failed lol. A manual update of the clock app fixed that problem though 👏
AnnaMaz
Beta Moderator
Beta Moderator
Hello @Stephencbr600,
I am glad the issue is now solved, thanks for the update 😊
