S21 FE not charging after using usb c to aux cable
(Topic created on: 25-10-2024 10:32 AM)
Members_dhr3qFm
Just as the title says.
TLDR; USB C to aux adapter stopped working one day. After that, the phone would not charge from a charger or a computer.
Not detected on computer.
When I plug the aux adapter in then out, get a notification of "USB connector connected" for a moment, and "USB connected disconnected". I do not get this notification with any other cables, plugged into a computer or charger.
On the way home, I tried using the usbc to aux cable to listen to something. It has worked in the past. This day it did not work.
When I plugged it in, a USB notification came up for a moment, then disappeared. No sound playing through the connected headphones.
When I arrived home, I plugged my phone in to charge but it would not charge any longer.
If I plug it into the computer or a charger, nothing happens. There is no notification or anything. But when I plug the usbc to aux cable, it will display "USB connector connected" for a moment, and "USB connected disconnected" when removed.
I have updated my software, restarted the phone, carefully cleaned the charging port in the phone, tried to boot it up in Recovery Mode but get the error of ([PDP] Back-up : fail setup-wizard [ FINISH ])
Any tips of what I can try next would be appreciated.
0 REPLIES 0
