How do I stop my s7 edge from draining battery
(Topic created on: 08-01-2021 06:02 PM)
eric93
  1. Disable Always-On Display. ...
  2. Delete Bloatware. ...
  3. Make Sure “Fast Cable Charging” is Enabled. ...
  4. Enable Ultra Power Saving Mode.
  5. Adjust Automatic Brightness Feature....
  6. Turn Off Edge Screen Features.
1 REPLY 1
ChrisM
SuperStar
Hi @eric93
Is the software on your phone up to date? Go to Settings > Software update > Download and install. Also, try a Soft Reset on the phone. This will end all processes and give the phone a fresh start. Press and hold the Volume Down and Power keys at the same time until the phone switches off and back on again.
Let us know how you get on!
