Samsung RS8000 - Plumbed Water and Ice
(Topic created on: 07-05-2020 11:54 AM)
Paulie24
Samsung Helper
Looking at the Samsung RS8000 with space max technology (617l). Does anyone one, if so is it easy to fit the connectors at the back? I previously, had a plumbed ice and water American FF and need to replace.
1 REPLY 1
FlorieJoy
Samsung Helper
I was told that you would be best to have a plumber to do these things, however I found the instruction booklet quite informative so it may help you do it yourself
