Fridge freezer RSG5UCRS water / ice dispensing on its own!
(Topic created on: 07-11-2024 09:59 AM)
Gtsloz19
Good morning,
I have a Samsung RSG5UCRS which has given us many years of service.
Fridge performs brilliantly.
The other day, the water dispenser just started to dispense water on its own.
A quick press of the push button and the water stopped.
If left on the ice function, the ice will all of a sudden dispense on its own also!
The switch feels solid and performs well when tested (during normal operation and push cup against it - it works and shuts off when glass is removed etc)
I have checked for error codes within the appliance and nothing is present.
Would this fault point to a faulty switch or controller PCB?
Many thanks!
Paul
1 REPLY 1
Ferenc75
Samsung Members Star ★
Good morning,
Did you check on the Samsung website about your fridge? Has some useful tips if no-one them helps then I would book a repair.
https://www.samsung.com/uk/support/model/RSG5UCRS1/XEF/?srsltid=AfmBOor2aBAc72h5pmEMyBT5FcYDgdE3m0JF...
