19-08-2023 08:02 AM
My Samsung American style fridge freezer ice maker is making ice ok, but ice dispenser flap just wont open whether set on cubed or crushed ice. Can hear motor etc when press receptacle up to switch, but flap simply won't open. Can open flap manually though so it's not seized up. The water dispenser is working fine. Other oddity is when I open freezer door, display panel shows temperature etc until door opened more than about 45 degrees & then display goes blank & ice dispenser makes loud clicking noise. Would a faulty freezer door switch cause ice dispenser flap not to open, or is it some other problem? The model number is RSG5UUBP.
26-08-2023 04:32 PM
Are you still having these same issues, or did you manage to get anything sorted out?
28-08-2023 10:50 AM
Still having the same issues. When freezer door halfway open the control display goes blank & repetitive clicking noise from ice dispenser (...even though set on Water dispense). Further oddity has developed too since my first posting - sometimes when I open freezer door past halfway get pinging alarm & error message 'PC Er' on display screen. When open fridge door & then shut the freezer door before re-closing the fridge door, the display comes back on again. I'm beginning to think it may be a dodgy display control panel, rather than original view it might be the freezer door switch?
