20-10-2022 10:50 AM
Hi,
I have an Ecobubble washing machine and have been keeping up the maintenance by cleaning the debris filter. I followed all instructions correctly, but i notice that the emergency drain hose is now slightly damp right at the end where it joins with the tube cap after doing a load of washing. I have done 3 washes since this, and another time there was a tiny bit of water from it, that fell below it.
I know it’s not a massive leak, but i am wondering if this is normal, or it it’s something i should be concerned about, as in will the leak get bigger?! I have checked and the cap is definitely on correctly. I don’t know if i am doing anything wrong in taking the cap off, as i have to turn and unscrew it a bit to release the cap, it won’t come off easily just by pulling.
Am i worrying over nothing? I don’t know for sure if this is how it’s always been as i have never checked before after cleaning.
Thanks for reading. Anyone can tell me if this is something to be concerned about?
20-10-2022 11:32 PM
Ok, thanks for all your suggestions
28-10-2022 08:45 PM
Just wanted to update, in case anyone reading this has the same problem. The problem has resolved itself since I last posted. It has stopped leaking without me having to do anything, which I am glad about.
