15-11-2018 10:46 AM
I have bought a WW80 Eco Bubble washer. I am having issues with the length of the drain hose. I find it is a few inches too short to reach the sink drainage connection. An extension hose would be overkill for the few extra inches needed so I'm looking for another solution. Other washing machines I've owned had the drain hose coming out of the machine at the bottom, as is the case with this Samsung. But unlike the Samsung, on other machines the hose was loose and could be laid along the kitchen floor or at and angle behind the machine, and then brought up and into the sink cabinet. This Samsung however has a blue plastic clamp securing the drain hose to the top right corner of the maching holding the pipe vertically up the right hand side, and this restricts the loose length of hose available. Can anyone advise if it is ok to disconnect the hose from the blue clamp without affecting the operation of the machines drainage system? Doing this would free up the extra length I heed to connect to the sink drain. I cant see releasing the hose from the clamp as being an issue but I hope someone can confirm this. I previously tried contacting Samsung for advice using thier live chat but this provided no answer and was frankly a waste of my time.
06-11-2020 09:14 AM
19-05-2021 08:38 PM
I've got exactly the same problem. Just had a WW10t684DLH delivered. The hose isn't long enough and doesn't fit onto the spigot. I've even ordered the extension kit mentioned from Amazon and that doesn't fit either! For a washing machine that cost over £700 I would expect at least a drain hose that fits or can be replaced but no way of taking it off without taking the machine apart.
