Advice please for a Samsung washing machine WW90TA046TT
(Topic created on: 01-06-2023 08:30 AM)
Nicola36
I have just bought a Samsung washing machine WW90TA046TT. I love it but the manual is confusing me. I have been mainly using the cycle for colours and synthetics. The loads I have been putting in are around 7kg but according to the manual the maximum is 4kg. This seems ridiculously light if you want to do a colour or mixed wash.
The machine still works if I put in more but I'm worried I will be damaging it in the long-term of I put in a heavier load than what is recommended.
If I stick rigidly to the weight recommendations then the only cycles I can use for heavy loads is the eco and cotton cycle.
Id be grateful for advice. Thanks
Nicola
2 REPLIES 2
nowdeleted
Big Cheese
Does the 7kg include the weight of the water or just the dry weight?? As wet clothes can weigh a lot and destabilise the drum.
Nicola36
No just the dry clothes
