Fermer
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Sujet d’origine :
Battery charging problem after UI 7 Android 15 update
(Sujet créé le : 11-05-2025 06:38 PM)
1114 Visites
Saj83
Hello All,
I am a Samsung S23 user, the charging situation is getting worst.... the graphics says it is connected to super fast charging and would charge in 1 hour... but the % doesn't move even after 30 mins ...it still remains at 5% charge...
This is right after the new UI 7, android version 15 update.
The customer service is very bad and points us to basis outdated troubleshooting steps.
…. do you have the same problem ?? Has anyone found a solution ?
Thanks
8 Réponses
rimka_27
Hello
Turn off battery protection and check if fast charging is enabled
0 Compliments
Saj83
Yes...thanks for the response...already done ...but still the problem persist!
Thanks
0 Compliments
rimka_27
Reset
Usb setting
0 Compliments
rimka_27
System applications
0 Compliments
KnightCyborg
SuperStar
Hello i suggest reset your phone. But before save your data with Smartswitch or Samsung Cloud, and one drive for pictures and videos
0 Compliments
Saj83
Hi, Where is it...i can't find....merci
0 Compliments
rimka_27
0 Compliments
Saj83
Thanks...did the setting...no improvement 😞
