Go to solution Solved
Data transfer using smart switch without being able to charge to 20%
(Topic created on: 01-08-2025 03:50 PM)
Members_4ECOd1X
Hello,
I have a Galaxy Z Fold4  that just died. I would like to transfer the files to my new phone (s25 ultra) using Samsung smart switch. The problem is that my phone won't charge past 15%, making me unable to transfer the files since the smart switch requires at least 20% of phone charge. Is there anyway i could still transfer my files to my new phone?
With kind regards,
Cemil
Products mentioned in this post
arianwen27
Samsung Members Star ★
Can you use the cloud backup button within smart switch? Then download the cloud backup onto your new phone?
5 REPLIES 5
arianwen27
Tourbillon De La Vie
Samsung Members Star ★★
Back it up onto pc using smart switch pc software
Obsydian
Will the device connect DeX to a monitor, is so it's helps the options mentioned here.
Always Cloud back up, I do, been burnt before 🔥
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
Members_4ECOd1X
I can, but I wasn't sure if that option allowed me to transfer everything. So what you are saying is that the transfer via cloud en wifi is identical.
arianwen27
I believe so yes. Smart switch should act the same way during a device to device transfer, cloud backup, backup to usb and backup to a pc.
Plus even if for some reason some things don't transfer, your old device will still have everything. A transfer copies the data, it doesn't delete it on the old device. So if you spot something is missing, you can just move it over manually
