Battery problems
(Topic created on: 30-05-2023 11:20 AM)
Taggerz
My phone was showing 7+ hrs charging time.😱 Tried most common solutions, nothing worked.
I went into settings BATTERY & DEVICE CARE, pressed MAINTENANCE MODE let it restart, then turned off MAINTENANCE MODE. Phone restarted, now it charges ok.🤞bk to normal charging time.🤔
3 REPLIES 3
Fiona26
Samsung Members Star ★★
Definitely recommend a restart or reboot once a week. Certainly helps with performance and certainly helps stop issues occurring.
Anonymous User
Not applicable
Thats sounds like your phone was stuck in slow charging...
If its ok now then it should probably be OK now...
BTW charging over usb takes longer than using the charger...
Taggerz
I've only had 1 real issue in 1 Yr.....SCREEN PROTECTOR ...... Samsung repair fixed within a hr. Don't know if thus is a common problem wiv flip & fold phones.🤔
