S25+ AOD battery drain
(Topic created on: 11-02-2025 08:46 AM)
joaocosta00
AOD is draining 12 to 13% of battery, this is not normal.
5 REPLIES 5
Glenntech
Samsung Members Star ★★
Depends on what period of time you are talking about
I know it used to used about 1% and hour. But there have been some efficiency improvements over time
Then also what sort of AOD do you have. I have a video one and so this will naturally used more
joaocosta00
Im talking about 24hours use, just have the clock setup, nothing else.
Glenntech
Over 24 hours seems quite normal
That's about 0.5% and hour
AndyWall73
So, my friend and I both have new S25 Ultra's and with even the same settings for AOD, mine consumes twice as much, currently mines on 3.06% yet his is half of that or sometimes less.  Makes no sense.  Anyone any ideas why this is?  To note his phone is 1 week older than mine, so is mine still learning my habbits ?
Claybob
I also have an AOD battery drain issue. I turned it off and the battery drain dropped dramatically. I like AOD and I hope Samsung finds a lower consumption compromise.
