How to achieve longer Battery and cooler temps after each update.
(Topic created on: a month ago)
AFS-Reviews
Voyager
If anybody has been experiencing difficulties related to Battery and Tempatures like I have with their : S22 ,S23, S24, and S25, then I have amazing news for you. You can fix them, all you need is a cable and any computer.
First, Plug your phone into your PC.
Next, Restart your phone. And when the phone vibrates and shuts off *FULLY* Push and hold SIDE BUTTON and VOLUME UP Release SIDE BUTTON once "SAMSUNG" logo appears and you will enter the Recovery screen.
And Then: Locate A page mentioning Cache. And clear your Cache.
And Lasty: Once your back on the main page. Go to "BOOT SYSTEM." and you will now have longer lasting battery, and cooler tempatures.
NOTICE:
Longer lasting battery may take a while since wiping your Cache deletes battery records and history, which helps boost battery length. But after 3-4 weeks. It will return to normal, and get longer and longer until it maxes out.
Tips:
Have routines setup to enable a light profile and power saving when outdoors, and if necessary, allow those routines to also lower FPS, and Resolution, for maximum power efficiency outdoors until you get home which will be guaranteed to have a charger.
You can also purchase a power bank
(RECOMMENDED BRAND: Juice, Samsung)
To extend your phones battery life depending on mAh.
1 REPLY 1
AFS-Reviews
Voyager
NOTICE:
I would like to inform you that to use the Recovery Menu, you use Volume up and Down to choose options, and the Side Button to Enter the said option.
And you do not need to do anything on your PC, It just needs to be plugged into the phone and switched on.
