Go to solution Solved
[HELP][SOLVED] Finding Missing Fonts
(Topic created on: 24-02-2025 08:41 PM)
GoanGeek
Samsung Members Star ★★
Hi
Lovely People.
I had bought lots of fonts when I had my S24 ultra.
Now having moved to the S25 ultra I dont see them anywhere.
Any idea how to find them
Thanks😊
PS: Was able to solve myself. 😇
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
GoanGeek
Ok.
[SOLUTION]
OPEN SAMSUNG STORE
BURGER MENU AT BOTTOM RIGHT
MY APPS ON THE TOP LEFT
Then THEMES on Top Right
Click on the Themes drop down Menu on the Left and choose FONTS.
PS: Samsung seriously needs to make this easier. Maybe put a Tab on the front page it self.1740432337425.jpg1740432337437.jpg1740432337446.jpg
5 REPLIES 5
johnz237
They don't automatically move over.
Go to Settings: Open your phone settings.
Navigate to Display: Select the "Display" option.
Choose Font size and style: Tap on "Font size and style".
Select "Download Fonts": You'll see an option to download new fonts, where you can access your previously purchased fonts from the Galaxy Store. It may be a pain, but you'll have to search for them.
Unless you mean they're not there?
GoanGeek
That's the issue.
Samsung doesn't seem to have option for downloaded fonts, unless I'm missing something 😕 .
I don't even remember the names of the fonts to search them 😂
GoanGeek
Ah never mind. Found them 😂
Found the answer.
Will post later😊
GoanGeek
Ok.
[SOLUTION]
OPEN SAMSUNG STORE
Members_0qFORuP
They're are no downloadable fonts that are free or to purchase......
