Samsung S24+ battery drain
(Topic created on: 23-04-2024 11:58 AM)
Tomass KK
I have been noticing some bad battery life for a long time now, heres a screenshot. I heard smartswitch could be a problem, when switching data from old phone to new one. Could wiping the cache partition help?
Mabye its because of my apps, but it doesnt show anything that really drains the battery.
I would appreciate any help!
UPDATE: I did factory reset my phone, and set it up manually, and the battery life already shows that the phone will last approximately 18-22h on a full charge. And i have enabled 120hz, 5G, GPS. And it's  still learning the usage patterns.
4 REPLIES 4
BandOfBrothers
Samsung Members Star ★★
Hi @Tomass KK
Wiping the phone's System Partition Cache Files Section would be the first step yes.
But if that does not help then backing up and a factory reset,  then setting up the phone manually maybe the next step.
Personally I use Samsung Cloud to move my data across and only use SmartSwitch for the Gallery.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Tomass KK
Thank you! Im home now, and i'm just going to factory reset it and update you, because I have a lot of unneeded stuff on my phone
Da1RiuS
Navigator
Did it work?
Tomass KK
It worked, but its not a huge improvement, because in my area the data coverage is not the best, and it still drains the battery like crazy, bu at least i can get through the day without charging it.
