S24 ultra system ui consuming so much battery
(Topic created on: 17-03-2024 08:14 PM)
Ashique 95
Hai guys
I feel system ui using little more battery is that normal? Is there any way to decrease the system ui usage ?
Thank you
5 REPLIES 5
Piper123
Samsung Members Star ★★
You've already posted about this. Can you please keep to the original post instead of recreating multiple threads on the same topic
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
Bigtasty65
Big Cheese
Your display has been on for over 8.2 hours since you've unplugged your phone! Do you work or is this just at weekends when you're off?
Ashique 95
 this display is very addictive today is my off day that's why it's less otherwise it will go  up to 10 hours to 11 . I'm trying to reduce the usage I'm not watching movies I'm not playing games and not using my phone for my work just normal use . How to reduce the usage of this phone if possible anyone help.  thank you !
Piper123
How to reduce your usage? Don't pick up your phone.
As @Bigtasty65 has said, you've had screen time of over 8 hours, that will use up most of your battery.
Ironically streaming (where you don't touch the screen) uses less battery then constantly touching the screen to do things.
Piper123
Waze uses a lot of battery. It requires location permanently on when in use.
Instagram is another high battery app.
QHD+ is another higher battery user as is 5g.
Not sure what your ask is here. You are using the device far more than "normal usage" and as such you are using a lot of battery power.
